Advice on future 2K build
13 minutes ago, Petz said:Budget (including currency): $2,000 USD
Country: United States
Games, programs or workloads that it will be used for: This will mostly be used for games as well as running mathematical models. I would describe my gaming habits as Bethesda centered, so heavily modded Skyrim, Fallout and Starfield (eventually).
Other details: I want a rig that will be able to run most games at 1440p above 60fps well into the future. My current part list is:
I've been debating whether I should go with the 7900xt or switch it for a 6950xt and save a bit of cash at the expense of longevity. On the other hand, I feel the 7800X3D might be going overboard (also slightly concerned about the cooler), but I'm hoping it'll get a proce cut or two between now and November, which is when I plan on buying everything. In the end, I want this to be a PC that lasts a while (I typically use my PCs for 7-8 years).
Would appreciate any thoughts or criticisms, thanks!
Super good build!
I'd keep the 7900XT unless you really need the $200 difference
I'd still get a slightly beefier cooler like an AK620 or TR PE120 just for less noise
