No post, CPU and DRAM LED on
Try to install the CPU again, perhaps is a mount pressure issue?
Also, double check the BIOS just in case. If after that nothing works, it may be a RAM or CPU issue, the only way to try is to put RAM from another system there and see if it works.
Also, you could try to wait for 10 minutes and see if something happens. When I first build my PC with a Ryzen 1600, I remember having this issue, but in the end it was just training the RAM.
Featured Topics
Overloke ·
Idkanythingaboutpcs ·
Posted in General Discussion1 -
ErpatGaming11 ·
Posted in Operating Systems2 -
1
3
ShadeBorderlands ·
Fankywanky ·
Seosamh_101 ·
Posted in Windows2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
