Wanting to upgrade, not sure what to get - any help appreciated!
5 minutes ago, SlimTimDoWork said:Budget (including currency): $700 - $1,000 USD
Country: U.S.
Games, programs or workloads that it will be used for: Gaming (new games & old games), work, etc.
Currently I have:
- MSI X570-A PRO
- AMD Ryzen 5 3600
- Gigabyte RTX 2080 Super Windforce OC 8GB
- Corsair LPX 32GB (2x16GB) 3200MHz C16 DDR4
- SAMSUNG 970 EVO Plus SSD 2TB - M.2 NVMe
- +2 other regular SSDs and 1 mechanical HDD
- MasterWatt 750 Watt Semifanless Modular Power Supply, 80 PLUS Bronze
- Corsair iCUE 220T RGB Airflow Tempered Glass Mid-Tower
- 3x monitors - left-side monitor is a Viewsonic 1080p (older), middle (main) monitor is an ASUS 1440p 165hz Gsync monitor, right-side monitor is a Gigabyte M32U (4k HDR Gsync)
I don't plan on upgrading my GPU yet. I'm not sure if I need to upgrade my RAM or PSU either. I'll be using the 2TB NVME for my boot drive, I game at 1440p, but do have the other 2 monitors listed connected.
I'm having some major issues with my current motherboard (I think) where my PC freezes up and then won't start for a long time. It says something about overcurrent on USB devices or something. I've tried a lot of things to fix this, but I'm just ready to buy a new MOBO/CPU/etc.
I'd like to buy a larger case with more space than this Corsair one, it was a pain to build in it. I'd also like a MOBO/CPU upgrade and probably a CPU air cooler. I think the 2080 super is fine to stick with for now, but I will be upgrading that in the not so distant future as well. And any other stuff that I may not be thinking about.
Any thoughts?
MSI's X570 boards were really bad if I recall. Their B550 boards were much better. For this budget, I'd get a new case, cpu, mobo, etc.
I'd get the Ryzen 7700x combo from Microcenter if you have one near you for $449. That takes care of CPU/RAM/Mobo
Then for the case I'd get a Lancool 216
