Budget (including currency): 1100.00 (cad)
Country: Canada
Games, programs or workloads that it will be used for: This will be a gaming pc however I don't super need the top specs for sure.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  My mouse and Keyboard are fine for now as well as my monitor. My current pc is a Dell office computer I got for like 200 used. So my build will be totally fresh. looking to get looking to get a consistent high frame rate at 1080p. Possible VR application in the future.pcbuildlist.png.57af773136e0672e11b678698eff6ab6.png
https://linustechtips.com/topic/1510740-my-first-time-building/
overspending a bit on looks. I would go for this instead
PCPartPicker Part List: https://ca.pcpartpicker.com/list/V7yY4s
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($188.50 @ Vuugo)
Motherboard: Asus TUF GAMING B550M-PLUS WIFI II Micro ATX AM4 Motherboard  ($169.99 @ Amazon Canada)
Memory: TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($39.97 @ Newegg Canada)
Storage: Crucial P3 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($61.99 @ PC-Canada)
Video Card: MSI MECH 2X OC Radeon RX 6700 XT 12 GB Video Card  ($479.99 @ Newegg Canada)
Case: DIYPC F2 MicroATX Mini Tower Case  ($69.98 @ Newegg Canada)
Power Supply: Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($102.25 @ Vuugo)
Total: $1112.67
Generated by PCPartPicker 2023-06-02 15:16 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1510740-my-first-time-building/#findComment-15968733
Hi. In my opinion you have way to powerfull PSU. See your CPU will consume about 65w. Your GPU (107w max workout) is not as powerhungry as are their big brothers gpus. Maybe you want to be future proof - the it is ok.  But you could go with 600w+Gold and even then it is with great safezone.
MoBo - Asus rog strix x570-e
CPU - AMD 5600x,
GPU - Gigabyte 3080 Gaming OC, 12GB, 384-bus
RAM Kingston Hyperx 2400Mhz(2x16Gb),
PSU 1000w Seasonic Prime 80+ gold.
https://linustechtips.com/topic/1510740-my-first-time-building/#findComment-15968737
Country: Canada
Crucial SSD may save you a little as they've had good buys lately. Corsair cases can be real hit or miss on their claimed airflow so I would check a review on that one, but you can definitely get a great case for less.
Corsair PSU I've had very good luck with and actually do recommend going overboard on. By that I mean gold and that high of watts is likely much more than needed but that leaves room for loss from age or more power for later upgrades. Plus if it's not running near full load it will be quieter with some even having a fanless mode for lower power use.
But yea overall may want rethink case and use that cost difference to bump up to a 6700xt which will be a world of difference in performance. 4gb card in this day is a bit rough.
https://linustechtips.com/topic/1510740-my-first-time-building/#findComment-15968750
CPU: *AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($188.50 @ Vuugo)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler  ($31.48 @ Vuugo)
Motherboard: *ASRock B550M Steel Legend Micro ATX AM4 Motherboard  ($133.94 @ Vuugo)
Memory: *TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($84.97 @ Newegg Canada)
Storage: *Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($74.97 @ Amazon Canada)
Video Card: *Gigabyte EAGLE Radeon RX 6600 8 GB Video Card  ($249.99 @ Canada Computers)
Case: *Fractal Design Pop Air ATX Mid Tower Case  ($129.99 @ Amazon Canada)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($139.70 @ Vuugo)
Total: $1033.54
Generated by PCPartPicker 2023-06-02 15:34 EDT-0400
https://linustechtips.com/topic/1510740-my-first-time-building/#findComment-15968763
