Help with pc part list revision.
Budget (including currency): $1000 AUD
Country:  Australia
Games, programs or workloads that it will be used for: CSGO Valorant Minecraft Forza horizon 5
https://au.pcpartpicker.com/list/3ZdPMb
Is the part list.
Any revisions?
Don't include windows cost
Wifi mandatory? 20 AUD is enough for an ethernet run from your room to your router.
PCPartPicker Part List
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor  ($139.00 @ Centre Com)
Motherboard: Asus TUF GAMING B450M-PRO II Micro ATX AM4 Motherboard  ($149.00 @ PCCaseGear)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($49.00 @ Mwave Australia)
Storage: TEAMGROUP MP33 PRO 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($75.00 @ PCCaseGear)
Video Card: PowerColor Fighter Radeon RX 6600 XT 8 GB Video Card  ($432.30 @ Newegg Australia)
Case: Silverstone FARA H1M MicroATX Mini Tower Case  ($45.00 @ Scorptec)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($111.00 @ Scorptec)
Total: $1000.30
Generated by PCPartPicker 2023-06-02 19:09 AEST+1000
You can go for CV650 if you just want to compress down, but this would give you an easy path of upgrade. Get 5800X3D for CPU and then 6950XT used or whatever the future holds for GPUs later on (and maybe dedicated 32GB kit, due to Ryzen having a really hard time booting a quad rank/4 sticks of RAM) and youll get a very good gaming system that shouldnt last this long.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My. Name. Is. Frill.
Total: $1000.30
Wifi mandatory
Total: $1000.30
Forgot to mention I want to record gameplay
Total: $1000.30
shouldn't last??
2 minutes ago, Sychicyuto said:
Wifi mandatory
Yeah then that means youre going to have to go down to 6600 non XT, or hit the roof of 105% budget barrier. Its up to you if going up to 1050 AUD would be fine for you.
Video Card: ASRock Challenger D Radeon RX 6600 8 GB Video Card  ($306.00 @ MSY Technology)
Wireless Network Adapter: Asus PCE-AX3000 802.11a/b/g/n/ac/ax PCIe x1 Wi-Fi Adapter  ($52.00 @ Umart)
Total: $926.00
Generated by PCPartPicker 2023-06-02 19:14 AEST+1000
1 minute ago, Sychicyuto said:
shouldn't last??
i mean shouldnt have, sorry. I wasnt being clear.
Just for the sake of clipping things or for actual VOD contents on youtube or similar platform? Because for the former the Radeon Relive recording app have improved SIGNIFICANTLY from the Polaris days where i have to reinstall it every week just to have a working recording, and the quality of Radeon Media Encoder in the RX 6000 series is decent enough for it that its telligible. For the latter though, its hard to chew to go for RTX 3050 for its new cost, id rather go for Intel platform with its igpu (non F variant) and record using OBS with Intel Quick Sync Video, or buy used RTX 3060. RTX 3050 is a sizable downgrade in performance compared to 6600XT.
Country:  Australia
Is the part list.
Any revisions?
Try this.
CPU: *AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($199.00 @ Centre Com)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler  ($29.00 @ MSY Technology)
Motherboard: *Asus TUF GAMING B550M-E WIFI Micro ATX AM4 Motherboard  ($199.00 @ MSY Technology)
Storage: MSI SPATIUM M461 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($61.00 @ PLE Computers)
Case: Deepcool MATREXX 40 MicroATX Mini Tower Case  ($55.00 @ MSY Technology)
Power Supply: Silverstone DA650 Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.00 @ PLE Computers)
Total: $1017.00
Generated by PCPartPicker 2023-06-02 19:25 AEST+1000
Total: $926.00
I am willing to squeese in 100 more dollars
I will pirate windows for a while
anyway i could fit 8 cores?
1 hour ago, Why_Me said:
Try this.
Total: $1017.00
You know any way i could fit 8 core processor into the budget?
It's 100 Australian Rubles more, and there's nothing to squeeze out of the already super budget tight suggested builds
Any GPU downgrade (RTX3050, ARC380, 6500XT...) will be way more crippling than what you'll gain with 2 more cores
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) 0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
Couple of small changes, but better
3600Mhz RGB ram
1TB NVME instead of 500GB
https://au.pcpartpicker.com/list/BMfWW4
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
3600Mhz RGB ram
Is the cpu cooler neccecary? Because i could use the stock cooler
23 hours ago, Sychicyuto said:
I came up with these modifications. https://au.pcpartpicker.com/list/9LrK6r note: I am willing to pirate windows so i will go over by $100
Yeah, there's nothing wrong with it... you may get overheating troubles, especially in your part of the world if you don't have aircon, but you can add a better cooler on later if you need it.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
