Curious. When querying SQL data in PHP, if I want to output data from a table result with a fetch_assoc, I'd have to always use column names. If I know the column position, is there not an option to just get the row for the position of the column rather than the name of it?
If an SQL table exists like this:
ID, DOB, first_name, last_name
and I want Date of birth and I know it'll always be the 2nd column, a pseudocode like it would be something like:
$row[1];
instead of how you'd always have to reference it:
$row["DOB"];
Sort of getting annoyed with how rigid PHP is when it comes to SQL. If I could just use positions I could make my code far more flexible instead of hardcoding each column on its own.
On second thought, I feel like this is a non issue and I'm just looking at a roundabout way of overcomplicating my code. Am I going insane?
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
PHP is anything BUT rigid about sql.
use SELECT * FROM table_name
use mysqli , either procedural or as an object. Use  mysqli_query  and then you have mysqli_fetch_array - https://www.php.net/manual/en/mysqli-result.fetch-array.php
$row[1];
$row["DOB"];
what PHP version are you using because you can definitively reference by index the column like
Quote
$row[1];
3 hours ago, venomtail said:
if I want to output data from a table result with a fetch_assoc.
Make sure you understand the differences in function names and their uses.
mysqli_fetch_assoc returns a row from the result set and populates an array using the column name as array keys, ie $row['DOB'].
mysqli_fetch_row, will return a row from the result set and populate an array using the column position as the index, ie $row[1]
mysqlI_fetch_all, with the 'mode' set to MYSQLI_BOTH, will returns a row from the result set and populates an array with both types. You can access either by column name or column index.
