Apartment design for ethernet
Solved by manikyath,
ideally, you make a space for network equipment (read: just a thick wooden board against the wall you can bolt stuff into) next to the fuse panel. have the uplink from the ISP arrive there as well.
then have every LAN port in the house lead back to a panel in this place.
then you bolt whatever modem you get from the ISP in the wall, presumably a network switch or two as well, and then just plug stuff in with cat6 cables.
