White PC Case with right side window
Solved by filpo,
22 minutes ago, Ichigo16 said:Hello
I'm looking for a PC case that has glass window from right side instead of the usual left because my PC sits on the left side of my desk. It also needs to be white in color preferably silent and not breaking bank ;).
It will be housing RTX4080 so it will need space for that. Looking forward to any suggestions
the lian li o11d evo, you can reverse it with instructions in the manual Lian Li O11 Dynamic EVO ATX Mid Tower Case (PC-O11DEX) - PCPartPicker
5 minutes ago, Ichigo16 said:I would prefer not to flip it upside down as that will not look very good. But honestly i'm not very sure it's annoying to be sure
The lian Li O11D Evo will be your best bet tho
