So I was filling my build and it wasn't leaking yet, After moving the reservoir and pump combo it started to leak. Luckily my computer was turned off when it happened. Alot of water leaked into my radiator and fans. I have tested my fans and they seem to be fine and working. I have taken apart my res, pump, fans and radiator, Should I take apart the whole build? Is there anything I should do?
Thanks,
You must "Quote" to get my attention​.
 ~IBIubbleTea - 20/07/2014
https://linustechtips.com/topic/150889-water-cooling-leak-help/
Leave it off for a couple days in a dry, warm place to let any residual moisture evaporate. Then you are fine to try filling it again, this time with more care :)
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2015410
Just the parts that got wet right?
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2015425
If the only thing that got wet was the rad and fans then you can dry them using a blow dryer. If any PC electrical components got wet then do not use a blow dryer. But make sure that they are 100% dry :)
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2015439
Ok so I dried everything, Should I fill the loop and test it? OR should I wait 24hours?
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2015627
If you are sure it is dry, build the loop outside your system and test it. When it is working with no leaks, then rebuild it inside your system.
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2015639
You can test your loop inside the system anyways, even if mobo etc got wet, just turn only the pump on.
I'm so pissed off right now... The part that is leaking is the Bitspower mod top and Bitspower mod kit. SO when tseted it outside of the loop it worked with no leaks, When I rebuild the loop again and test it, it would leak. What da heck is going on...?
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2016028
pump o-ring prolly got pinched or "wrapped". when installing the mod top, i
will use a film of silicone gel to lubricate the o-ring as to allow it to seal, but
not get twisted as applying the mod kit pump cover. happens a lot with D5
vario as twisting the pump to align the vario switch on the pump cap.
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2016084
Where can I get this "silicone gel"? Also can you link me this problem with a fix from other sources?
So I have taken out the Bitspower top, mod, res and pump and the fans and radiator that got wet. I still have the other parts in my computer such as cpu, gpu block and radiator which still has water in them, should I try to drain it or leave it in there, as I might work on it tomorrow again...
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2016966
what is left in the system is fine, just guard against movement or tipping.
drug store, supermarket, home store all have toxic-free silicone lubricant.
a 2ounce tube is plenty.
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2017922
Just wondering if these are the right ones?
http://www.jlaquatics.com/phpstore/store_pages/product-info.php?product_ID=mc-sil03c
http://www.homedepot.ca/product/ge-silicone-i-kitchen-bath-sealant-clear-290-ml/941925
If so, Do I place the o ring in first then put the gel on top of the o ring? Sorry if I'm asking too many questions, Really pissed off.
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2018124
For a second, I thought you had the same problem as me. My Bitspower pump top was leaking too, but it was leaking out of the acetal side, not the O-ring...
Ya, It wasn't the top, it was where you connect or screw the top to the mod kit area.... :/
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2018152
nope, lubricant, not sealant. take a dab of lubricant on finger(s) take o-ring
and slide o-ring between fingers with lubricant. should make o-ring shiny,
not clumpy. reinstall.
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2018278
This? Really want to make sure, Also won't this get into the water as water is flowing against it...?
http://www.homedepot.ca/product/silicone-lubricant/910532
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2018370
You should have probably got a pump from Swiftech....
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2018665
My heart jumped there for a second, this could have been funny.
Just kidding :3
My Rig "Jenova" Ryzen 7 3900X with EK Supremacy Elite, RTX3090 with EK Fullcover Acetal + Nickel & EK Backplate, Corsair AX1200i (sleeved), ASUS X570-E, 4x 8gb Corsair Vengeance Pro RGB 3800MHz 16CL, 500gb Samsung 980 Pro, Raijintek Paean
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2019140
Wrong, all the D5 are identical to each other, brands do not matter, only the support and warranty changes.
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2019154
Well I do have the mcp655 but u don't think there is a differences.
Do you think using the mcp655 o ring instead of the bitspower might help?
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2020161
Yeah that's what I was thinking about suggesting you to do - I think Swiftech pumps are just a higher quality. I mean, bitpower have good reputation for their fittings and reservoirs but for the pumps...I rarely see people buying a bitspower pump, most WC builders I met around the internet, get pumps from one of those brands - EK and Swiftech, sometimes XSPC.
If you ask me for radiators, I would say Alphacool - only because they make their rads as thick as 80mm, but if you don't have the space to put them, again EK, Swiftech and XSPC are there for you...
I know, maybe not all of you will agree with me but i have just looked at many builds and i've seen what people usually choose and rate high. It's not always about the brand, since all of them have great reputation, but it's always that some parts are bought more, reviewed better and rated higher from one brand than another.
Do you want me to share my "planned" build for this year?
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2022742
there ya go. just a dab-will-do-ya!
I think I found where it was leaking from. Look at picture.
Some of the screws thread were wet and one of them even had water in the screw hole...
https://linustechtips.com/topic/150889-water-cooling-leak-help/#findComment-2022873
