5 minutes ago, freeagent said:
My fans are in my sig lol.. pretty weak 🙂
T30 tho.  but here is the part that u might have overlooked, i run
1x 480thicc  push/pull
1x 360     push/pull
1x 240thicc  pull
1x 120thic   push/pull
dont need more than 30cfm then 😛
Attaboy!
No loops for me, so air is my friend 🙂
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
38 minutes ago, freeagent said:
Right, so because you don’t use your pc for intensive tasks, you can get away with a bunch of slow breathers.
I built my PC entirely around the idea of shoving as much hardware as I could (within budget) into the smallest box I could while staying as close to inaudible under load as possible. Your PC doesn’t need to sound like it’s preparing for liftoff under load, mine is functionally silent while getting its ass blown out because the fan curve maxes out at 650RPM with an idle of 450-500RPM, even though nothing is at stock clocks. My 2080 is overclocked yet slightly undervolted, as is my 12600KF.
Do tell how I never use it for anything intensive though just because it’s extremely quiet though.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
13 minutes ago, freeagent said:
Attaboy!
did a quick test,
max fan speed(3k for T30s, 2k(ish) for P12's, 2k for 12x25, 2k for D30s)
vs
cannot hear them at all
4c difference (cine r23  40k points)
1 hour ago, NorKris said:
did a quick test,
vs
What happens when you heat soak your loop? Have you tried?
Who the feck are you and why are you talking to me like that lol?
Norkris and I have been bantering back and forth for months.
