Greetings everyone,
I got myself 2 of Phanteks T30 because of the raving reviews and I can't for the life of me get them to run faster, they are basically running silent.
I got a Lenovo Legion Tower 5 using a Lenovo MoBo model "3753" running this horrible Bios "O5LKT22A" version, it has no fan curve options.
I have tried FanControl, SpeedFan and HWInfo and none of those detect the T30s
HEELPP PLEASE!
https://linustechtips.com/topic/1507261-phanteks-t30s-help/
Nice fans are pretty silent, a lot cap out at or below 2000rpm so they'll never get very audible even at max rpm. T30s specifically only reach 2000rpm, rated at 27.3 dB (A), which seems to be around or slightly below the average volume of whispering. Unless you stick your ear inside your PC, they should be basically inaudible.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942255
If the motherboard doesn't offer PWM fan control, you can get an external PWM controller with hardware buttons for RPM control. Or something software related like from Corsair.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942262
20 minutes ago, Resperekt said:
Greetings everyone,
HEELPP PLEASE!
Don't the fans have a selector switch to set speed anyway ??
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942271
Not for speed but PWM range, IIRC. Setting the max RPM of 1200, 2000 or 3000.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942274
Thanks! guess I'll go with the external controller..cause ICUE doesn't see fans either.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942796
what icue controller did u connect them to?
10 hours ago, Zando_ said:
 T30s specifically only reach 2000rpm, rated at 27.3 dB (A). Unless you stick your ear inside your PC, they should be basically inaudible.
T30's are 3k RPM. and at 2k they are VERY noticeable 😄
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942802
That would only be if the fans built-in switch is still set to the middle setting (performance), which is the default, as it maxes out at 2,000 RPM. Hybrid mode maxes at 1,200 and advanced mode at 3,000.
HEELPP PLEASE!
Check the switch and make sure it is on performance or advanced. Otherwise, aside from the great advice from everyone, are you using a y-splitter?
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15942896
I was pleased with how quiet they are at that speed lol. You got soft with your soft fans 😄
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943036
Icue will only see fans connected to a Corsair USB fan controller.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943066
11 minutes ago, NorKris said:
pff 😛  i got 17 fans on my system 😛  (2  t30's)
So.. that doesn’t mean anything if they are only like 30cfm 😄
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943108
What? I only have 10+2. 😆
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943113
1 hour ago, NorKris said:
ofc it does, what do u mean? lol
At only 30cfm that is a lot of noise for nothing.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943224
weeeeell,  30cfm is almost the definition of "u cannot hear anything "
there is a reason Daniel from singularity computers  and Linus made their pcs in a certain way
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943232
Right, so because you don’t use your pc for intensive tasks, you can get away with a bunch of slow breathers.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943267
Ahhhh. Thanks for the double check 👍. Checked the page again, they don't put that on the spec sheet, you have to scroll down to the image marketing blurb stuff where they explain it.
Nah. Your cooling setup dictates your fan speed. If your hardware has overkill coolers - or you're on appropriate watercooling - you can run fans at a very low rpm while absolutely blasting your hardware with 0 issues. I run my decently OCed 6950X (4.0, it'll do 4.2 but then does get hotter than I would like) + 2060 Super loop on a single 360 slim rad and can keep fans almost inaudible without having any problems cooling. More surface area = can run fans slower and get the same cooling perf as a smaller cooling setup with a freak amount of airflow. Both good solutions to the same problem, depending on whether you care about noise or not.
Mouse: EVGA X17
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943294
Games don’t blast hardware though. F@H, WCG, Rosetta are programs you can run that will test how good your cooling really is. I know my cooling is good, and I am not using insane fans.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943307
That sort of testing is exactly what I mean by "blasting". With a proper cooling setup you can put your PC through the damn wringer and have it never make anything above a subtle whoosh (or slight coil buzz from the GPU, that's luck of the draw though). Loudness of the fans doesn't mean someone is or isn't using their PC for intensive tasks.
Mouse: EVGA X17
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943314
 imean. my cooling setup blasts if im prime95 and furmarks at the same time at 30cfm   370w + 340w  easy
dont know what ur onabout,, oor wait.. aaah ofc u need 70-100cfm  for ur .Ai...co.. know  XD
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943319
I don’t run at stock clocks, but it’s good that you do.
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943320
My fans are in my sig lol.. pretty weak 🙂
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943323
I'd prefer to run stock clocks, but I have a penchant for old HEDT that needs to be clocked up to run modern games well, so I haven't had a main PC run stock clocks in years. I think the last time was when I had an i5 8400 as a short-term stopgap before I got my X99 kit.
Mouse: EVGA X17
https://linustechtips.com/topic/1507261-phanteks-t30s-help/#findComment-15943327
