I have a 3570k and the almost only PC parts reseller here at Finland has taken their all good 1155 motherboards out of the market exept a Gigabyte Z77x UP7 which costs about 521 usd. Which is alot atleast for me.
So i'm going between the Z77 board which costs 521 usd and a bundle which consists a Saberthoot Z87 and a i5 4670K and this costs about 617 usd.
I also could buy a cheaper Z87 and a 4670K with smaller price.
So which one should i get?
https://linustechtips.com/topic/150676-help-me-im-stuck/
Go with the 4670k. It's newer and better.
https://linustechtips.com/topic/150676-help-me-im-stuck/#findComment-2013140
I have a 3570k and the almost only PC parts reseller here at Finland has taken their all good 1150 motherboards out of the market exept a Gigabyte Z77x UP7 which costs about 521 usd. Which is alot atleast for me.
4670K
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/150676-help-me-im-stuck/#findComment-2013153
Depending ofc whats your definition of good mobo, for me it seems that Jimms has several good options beside UP7. http://www.jimms.fi/listaa/981 tietokonekauppa.fi has bit more limited but still few good options like UP4 from Gigabyte.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/150676-help-me-im-stuck/#findComment-2013741
4670k. Cheapest Z87 overclocks like the best. All that matters is the chip/cooling. You will be from 4.1-4.7 and where you will be? No idea. Haswell has new instructions, and higher single core performance. Ivy wasn't exactly Sandy overclocking. You can "lose" on both, but if you "lose" on Haswell it is still fast.
You don't upgrade from an Ivy to a Haswell, and you don't even upgrade from Sandy (if you got a good overclocker) to Haswell, but you don't buy a Ivy over a Haswell if they are same price. Haswell can excel in some things due to the new instructions. Things like Dolphin emulator already use them and a Haswell blows away Sandy/Ivy in it.
https://docs.google.com/spreadsheet/ccc?key=0AkEUvobPn_DcdEo2aEhhdUpnU01tYUtNM3ZVX2d6SkE&usp=sharing#gid=0
Will we see those new instructions used in games? Might be awhile, but grab the Haswell just in case.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/150676-help-me-im-stuck/#findComment-2014071
Well aesthetics mean much to me, and the mb's on Jimm's and Tietokonekauppa are not pretty enought for me. The performance is ofc important too but if it's ugly i won't use it. Also i don't want a dirt cheap mb, and those dirt cheap mb's Jimm's only seems to have in their warehouses at the moment (LGA1155) and i don't like wait lol
https://linustechtips.com/topic/150676-help-me-im-stuck/#findComment-2015500
