Hello, I recently bought the rtx 3060 https://www.amazon.com/MSI-GeForce-RTX-3060-12G/dp/B08WPRMVWB/ref=mp_s_a_1_4?crid=1OFMRJX8BJ625&keywords=rtx+3060&qid=1683151493&sprefix=rtx+3060%2Caps%2C109&sr=8-4 and I was wondering what Lian li RGB cable works with this. Can someone link the product plz
https://linustechtips.com/topic/1504719-msi-rtx-3060-cable/
Huh?? Graphics cards don't have RGB cables.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1504719-msi-rtx-3060-cable/#findComment-15923095
He most likely meant Lian-Li strimer.
Strimer Plus V1
https://www.amazon.com/LIAN-PW8-V2-ADDRESSABLE-STRIMER-8-PIN/dp/B085DR8STN/ref=sr_1_5?crid=HAXOFT5TLDP2&keywords=strimer+plus&sprefix=strimer+plus%2Caps%2C432&sr=8-5
Strimer Plus V2
https://www.amazon.com/LIAN-Strimer-Plus-Pin-PW8-PV2/dp/B09ZRP4K8B/ref=sr_1_6?crid=HAXOFT5TLDP2&keywords=strimer+plus&sprefix=strimer+plus%2Caps%2C432&sr=8-6
Either will work, but idk what's the actual difference between the Strimer Plus V1 & Strimer Plus V2. Heard it's brightness & the flexibility of the cable.
But since your GPU only uses a single 8 pin, and that strimer cable comes as double 8 pins, and I dunno for sure whether you can remove 1 set of 8pin from the LED strip bracket since i don't own one. You most likely will be leaving 1 8pin connector on the strimer just hanging around unplugged to anything.
AFAIK, Lian-Li doesn't sell a single 8pin strimer.
And you probably need to buy the controller as well.
https://www.amazon.com/Lian-Li-Strimer-L-Connect-Controller/dp/B09ZKSPKCF/ref=sr_1_2?crid=1TQJ8FYN094LZ&keywords=strimer+V2+controller&qid=1683154152&sprefix=strimer+v2+controll%2Caps%2C323&sr=8-2
Refresh before you reply
https://linustechtips.com/topic/1504719-msi-rtx-3060-cable/#findComment-15923115
Strimer Plus V1
Strimer Plus V2
He answered my question thanks.
https://linustechtips.com/topic/1504719-msi-rtx-3060-cable/#findComment-15923254
I know it might be not in your times but a lot of people are pretty damn long in the computer industry and when someone say RGB cable without elaboration, theyll default to this. Be specific.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1504719-msi-rtx-3060-cable/#findComment-15923346
