Ethernet does not work instantly upon boot up.
Guest
I've had this issue ever since I started using ethernet, and I've found it to be really frustrating.
The internet I have it hooked up to is a Telus Wifi 6 (???) router, with a Monoprice Cat 5e cable.
It looks something like this, but it's 100 feet long. I have it taped on the walls from a few rooms and floors to my own room.
I also use the B560M bazooka motherboard, which comes with the Realtek 2.5G ethernet adapter. I use that for my internet uses. I have the realtek ethernet drivers isntalled too, so I don't really know what's going on, and what makes ethernet unusuble upon bootup.
To clarify: Yes, the internet works after a while, but it's frustrating. I want to figure out how to stop it from idling at "no internet" when i log in.
How long is "a while"?
My ethernet usually also take a 5 seconds or something to connect, atleast that is what the ethernet icon in the taskbar shows.
PC Setup:
HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel
Intel Core i7-10700K + Corsair Hydro Series H100x
G.SKILL TridentZ RGB 32GB (F4-3600C16Q-32GTZR)
ASUS ROG STRIX RTX 3080Ti OC LC
ASUS ROG STRIX Z490-G GAMING (Wi-Fi)
Samsung EVO Plus 1TB
Crucial MX500 2TB
Crucial MX300 1TB
Corsair HX1200i
Peripherals:
Samsung Odyssey Neo G9 G95NC 57"
Samsung Odyssey Neo G7 32"
ASUS ROG Harpe Ace Aim Lab Edition Wireless
ASUS ROG Claymore II Wireless
ASUS ROG Sheath BLK LTD'
Corsair SP2500
Beyerdynamic TYGR 300R + FiiO K7 DAC/AMP
RØDE VideoMic II + Elgato WAVE Mic Arm
Racing SIM Setup:
Sim-Lab GT1 EVO Sim Racing Cockpit + Sim-Lab GT1 EVO Single Screen holder
Svive Racing D1 Seat
Samsung Odyssey G9 49"
Simagic Alpha Mini
Simagic GT4 (Dual Clutch)
CSL Elite Pedals V2
Logitech K400 Plus
Apologies. It takes around  1 minute. When the computer boots up, I log in, and I wait for around 1 minute for the ethernet to start up. Steam and Discord don't open properly because the ethernet is taking a long time to initiate.
