2 minutes ago, Cloudsy324r42344 said:
How am i supposed to do that, if i dont even have internet on my pc
Download them on a different pc, put it on a flashdrive, move the file over.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1503434-problem/#findComment-15912914
5 minutes ago, Tomberry said:
i agree with what @tkitchand @whispous said about the driver but should windows not come with a basic driver to counter issues like this??
nope, a whole bunch of NICs don't have any way to work in windows until you install the proper driver.
https://linustechtips.com/topic/1503434-problem/#findComment-15912980
Just now, Theguywhobea said:
get another computer and a flash drive. Download drivers on that computer, place them in flash drive, place flash drive in new computer.
That, or just plug it in and hope that microsoft installs them automagically
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
https://linustechtips.com/topic/1503434-problem/#findComment-15913079
You really didn't need to make a new thread, as the answer was already provided to you in the other one. Find another computer, download the installer for drivers you need from the motherboard manufacturer's website to a USB drive, plug it into your computer, install.
https://linustechtips.com/topic/1503434-problem/#findComment-15913080
Alrigjt
Didnt see ur comment srry
https://linustechtips.com/topic/1503434-problem/#findComment-15913087
I just see lan for intel thats like for networking...
https://linustechtips.com/topic/1503434-problem/#findComment-15913100
You sure its a realtek network adapter on that board? Because the manufacturer seems to think it's intel.
I just dont knkw anymore my mind is already frustrated enough. So basically. The Ethernet itself from the router is realtek, i go on their website (realteks webs) and downloaded the "Win10 auto installation program (NDIS)" to the flashdrive, now i went to the motheboard's website and i just see (thats network related) "On-Board LAN(intel)" (the mobo is b560mx e pro) now i dont know if i did already download the driver from the website or not. My mind is so frustrated that i just get mad from just sitting down lol.
https://linustechtips.com/topic/1503434-problem/#findComment-15913113
Never had to install Ethernet drivers on a new system, it's included in Windows install since ages
https://linustechtips.com/topic/1503434-problem/#findComment-15913128
4 minutes ago, YoungBlade said:
According to the BIOSTAR website, the network adapter is Intel. The drivers can be downloaded here: https://www.biostar-europe.com/app/de/mb/introduction.php?S_ID=1014#download
Did already download the intel LAN  and i dont even know why
https://linustechtips.com/topic/1503434-problem/#findComment-15913132
