2 minutes ago, Cloudsy324r42344 said:
Did already download the intel LAN  and i dont even know why
So you already installed the intel driver on your pc ?
Refresh before you reply
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913142
Not like that. I meant to say I downloaded both Realtek win10 auto installation program(from their website) and Intel LAN (from motherboards manufacturer's website) to my usb flash.
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913148
If you are trying to install a driver for the ethernet card/chip on your motherboard then you install the intel one.
Since based on Biostar website seems it (Intel) is what came with your motherboard.
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913181
so what youre saying is. i should downlaod the intel lan and unzip the folder on my new pc, is that correct?
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913189
Still wondering what's your issue, Ethernet should work out of the box with any basic Win install, supposing your network is properly setup...
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913190
Not just unzip.
Unzip it, then install the driver by double clicking the executable in the folder you get after unzipping.
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913193
Not just unzip.
will try to now unplug al the cables from ths pc to the new one and do that, if it wont help then im going to sleep because tmrw i have an exam
https://linustechtips.com/topic/1503434-problem/page/2/#findComment-15913202
