Can i power on a GPU that needs 2 x 6+2pin with just one 6+2pin just to see if it works?
Solved by Beerzerker,
50 minutes ago, OhYou_ said:you cannot without modifying it.
wait for new psu is your best option.
sounds like it is not for you but you can power it up using an adaptor that splits the 6+2 into two 6+2 but now you are waiting for the adaptor in the same time the psu will arrive.
THIS.
Don't even try it or you might be waiting and paying yet again, just more $$ paid out the next time and probrably more waiting too.
You have more time than money here and you can't change the fact you'll be waiting on it so let that time pass and leave it alone untill the new PSU arrives.
