5900x with peerless assassin 120 temps and clock speed?
41 minutes ago, johnno23 said:your temps are fine on a 10 minute run but your 5900x should hit 4.5 on all core.
I also run a 5900x but run it on an x570 Aorus master.
I have zero overclocks and xmp dissabled and my cinebench scores are 22841. my cpu hits 82c sometimes 83c
As someone who has that exact same setup, not really. Boost algorithms are very weird with how it does frequency, and it's not uncommon for it to report one frequency but perform like something else. I've seen it do 23000 points while reporting 4.4GHz, and I've seen it do 18000 points while reporting 4.8GHz (both with realtime priority so background tasks don't interfere with the score), all depending on the BIOS, AGESA, etc. The only thing you can judge is the score itself, the reported frequency is kinda irrelevant.
To OP, I haven't used a PA120 on my 5900X, though I did have it on a Scythe Fuma 2 for a week. Temps were fine, mid 80s, and it PBO cinebench scores were in the 22500 range (give or take 500 points, this was something like a year ago). The PA120 is a very similar cooler, performance should be better than the Fuma 2 going by GN's numbers, so I'd expect it to be perfectly fine. It'll be a major improvement over the stock cooler.
