Why is my PC power cycling?
Solved by CommanderAlex,
15 minutes ago, D.G said:This situation has happened with a different power supply and I thought it was that so I replaced it with the one I have now. It worked for around a month and then stopped working again. Not sure if that's sufficient though.
That definitely sounds more like to me the motherboard is on it's way out. Are you able to check the voltages? There is a tolerance of +/-5% for 12V and 5V and +/-4% for 3.3V. Keep in mind software voltages are not completely accurate so probing with a multimeter would provide actual voltage readings.
