Newand first build, no post, pls help
Based on the information you provided, it seems that you have replaced your motherboard and GPU but still have the same problem. You mentioned that someone told you a BIOS update was needed for your motherboard for your CPU and motherboard to be compatible. It is possible that this is the issue. You can check the compatibility of your RAM with your motherboard by visiting MSI’s website. The light next to the power button flickering indicates disk activity which means that your computer is trying to boot up. You can try connecting your display to the GPU display out socket or the motherboard one to see if it makes a difference. If none of these work, it might be worth checking if your RAM is compatible with your CPU and motherboard. I hope this helps!
