*HELP Malware
Pumim
Hi guys,
I recieved some malware and im not sure im free of it yet?
I downloaded malwarebytes to try and remove it, but it doesnt find anything when I scan it, though windows says quarantine failed.
I spoke to support from NZXT and they say their downloads doesnt come as a ZIP, but as a .exe.
Anybody that can help?
5 minutes ago, Hinjima said:
Delete that zip, scan and then download NZXT's exe
2 minutes ago, _Omega_ said:
try downloading Malwarebytes
I did already delete it. Both Avast anti virus and Malwarebytes doesn't find any threats. Windows does keep coming up with this message about the trojan /.zip file saying quarantine failed
If you can not run an AV software, prepare a bootable USB from one of them... Malwarebytes, Kaspersky and more are offering tools to create a bootable USB to disinfect a system that is "too" infected
i wouldnt use kaspersky thesedays because....yaknow. zonealarm is very good as well (by checkpoint)
I just factory reset the PC. Reinstalled windows from cloud. Windows doesn't detect anything now, but would it detect malware on BIOS or the GPU ?
How often does the malware infect BIOS / GPU ?
I wouldn't worry about this, altough i would definitely make sure that your bios is up to date, since especially older motherboards, have had many updates for things like malware.
Even if you have a newer motherboard, i would personally always update the bios for things like these, aswell as performance.
Press the Windows key +X and choose Apps and Features. See if NSXT is installed, if so, Uninstall it
Browse to C:\Users\kpumi\Downloads\ and Delete NSXT-CAM-Setup.zip
On another internet device, download the Cam driver https://nzxt.com/software/cam
Also, you do not need Avast Anti-Virus or any other AV software, not including Malwarebytes, which is for Malware. Windows Security works  just as well and is included with Windows. We suggest you uninstall Avast using the Avast Clear Utility
Thank you very much! - I'm having another issue with my PC crashing all the time, so I had to reset OS anyways... Appreciate all tips and tricks definitely useful.
