so i have the dell OD-OLED and it can do HDR 400 true black or HDR peak 1000 and i have no idea which i should really be using? as far as i can tell the 1000peak is brighter but not by much and 400 true black gives better colours/contrast but i find it really hard to tell the difference between them if at all so dose it even matter which setting i put it on?
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/1495638-hdr-standards-help/
Which do you have? The DW or DWF? Have you watched any content on these displays that talk about the two modes?
Tim talks about the two modes in the latest video but he's got much more coverage of them and individual reviews.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1495638-hdr-standards-help/#findComment-15853264
If it's the AW3423DW, then use the 1000 mode. They're both pretty accurate and the 1000 mode gives more brightness for a better HDR representation.
If it's the AW3423DWF, then the 400 mode is a lot more accurate. The 1000 mode is overly bright and generally inaccurate in terms of brightness, but that might be fixed in future firmware updates.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1495638-hdr-standards-help/#findComment-15853906
Personally, I think 400 nits mode should be the mode of choice most of the time but it's really up to you.
1000 nits give you a brighter image (but not really 1000 nits in any meaningful windows), 400 nits is not as bright but offer much more stable ABL. And I would value that a bit more than the slight brightness increased.
But if ABL didn't bother you anyway then feel free to go 1000 nits
https://linustechtips.com/topic/1495638-hdr-standards-help/#findComment-15854010
whichever looks better for you
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1495638-hdr-standards-help/#findComment-15854393
