Just now, GOATWD said:
i would say go for it (if it doesn't work you can just get your money back)
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1495243-pci-front-io/#findComment-15850511
13 minutes ago, GOATWD said:
It will work, but you will not be able to use all at the same time and expect to get full speed. It's pcie 2.0 x1, so limited to 5Gbs max
https://linustechtips.com/topic/1495243-pci-front-io/#findComment-15850525
The card uses a USB 3 hub  that creates 4 ports - 2 ports go to that usb 3 20 pin header, and 2 ports go to that new USB 3 front panel header ( needs to be two so that the header will work no matter how you insert a usb device into the front panel connector - depending on orientation, one port out of the two is used.
Don't exactly know how the conversion is done between the pci-e x1 and usb 3 because the controller is a hub chip, probably there's a single pci-e x1 - > usb 3 controller on the pcb, and this hub chip is connected to the usb 3 controller.
But yeah, as designed, every usb port is not capable of more than 5 gbps.
The actual pci-e x1 is capable of 500 MB/s (if it's pci-e 2.0 slot)  or around 975 MB/s for pci-e 3.0 slots, real world though due to overhead, you're looking at maybe 480 MB/s  or 960 MB/s
With usb 3.0, realistically, again due to overhead, you're not gonna get more than 4.5 gbps or around 550 MB/s , so barely above what a pci-e 2.0 lane can do.
https://linustechtips.com/topic/1495243-pci-front-io/#findComment-15850580
full speed isnt neciory i just need usb 3.2 gen 2 for usb c
https://linustechtips.com/topic/1495243-pci-front-io/#findComment-15850585
