H100i high temps after case change
Solved by GeTecknics,
OP's housemate.
Ambient tempurature - I'm wearing 3 pairs of socks and an army jumper.
My FX8350 w/ H100i is running 20c idle with no overclocking... same thermal compound mostly same components but I'm on a Sabertooth and FX8350.
My A+ Technician's certification isn't helping us diagnose this either and I helped put this build and the last one together. No cabling is different, same thermal paste, same fans, same locations. Only difference is the case.
looks like the h100i is messed up then maybe a pump problem might just be easier to rma then deal with it yourself
