Deepcool AK400 Zero vs AK400 and AG400
Solved by freeagent,
2 minutes ago, Noobbuilder69 said:I was originally going for a be quiet! Dark Rock Pro 4. But everybody I asked said that I should get a Deep cool Ak400 or AG400 because it is basically the same but cheaper. I want sure if one fan was enough so I looked into the Deepcool line and found this one with tow fans. Seemed like a good middle way.
I would consider the Thermalright PA120, or even the new PS120. Its basically a PA120 with a seventh pipe. Should be on Amazon for about 40 bucks.
