Hello all!
So, I'm going to water cool my computer in the next week or two.
I've got most of the loop figured out, but I need a few last things to be figured out.
I need a pump for my loop, and I was looking at the Swiftech MCP655-PWM pump, but the issue I'm having, is it's $212 (USD).
I need a pump that will work for my loop, but will be cheaper. What addons for a pump are worth while? PWM? Variable Speed?
And just some general help on what would be recommended would be nice
Loop contains:
2 GPU
1 CPU
1 Mobo (Gigabyte G.1 Sniper Integrated)
2 360mm Radiators (One is an Alphacool Monsta)
1 120mm Radiator
250ml Tube Res
Thanks all :)
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/149506-pump-for-my-loop/
d5?
disregard that, i'm retarded.
But hows that 200$? O.o
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997525
I'll probably get hanged for this, but I have an EK DCP 4.0 and it runs great, very powerful pump. You do need to dampen the vibrations correctly and maybe get a controller to undervolt it a little, but it's completely silent if you do that.
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997558
Just suck the liquid through the tube and spit it out again. No need for your fancy pumps.
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997573
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_201&products_id=29094
It's cheaper than I wrote (I think I was including a pump top [$50])
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997594
If you are going with aftermarket tops and housing, of course it will be more expensive. On the other hand, http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_201&products_id=30154 at $75 is also a D5.
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997833
Doesn't this still need pump top? That would add back another 50 bucks or so.
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997881
Yes, it does. Pump tops can be had for less than $50: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_439_771&products_id=31996 ($25)
Now that does not mean that this is the best performer of the lot but for $100 you have a fully function D5 if need be.
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1997914
Is this functional enough to go through 4 blocks, and 3 radiators?
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1998217
Depends on the blocks and radiators. Typically D5 pumps are for low restriction, high flow loops and DDC pumps are for high restriction loops.
So I should shoot for a DDC pump instead then?
(GTX 780 block x2, CPU Block, Gigabyte G.1 Sniper Integrated Mobo block, Alphacool Monsta 360mm Rad, Second 360mm rad [Haven't decided, hoping for high FPI], XSPC 120mm Rad)
https://linustechtips.com/topic/149506-pump-for-my-loop/#findComment-1998429
