Loop order doesn't really matter in a custom loop, just make sure the pump is getting fed.
Ideally, you want the water/coolant to be cooled down by the radiator before it makes it back into the res/pump.
Res/pump to be physically at the lowest spot (i.e. bottom of the case).
For a single radiator setup...
Pump/Res --> GPU / CPU --> Radiator --> back to pump/res
What are your system specs?
How big is your single radiator?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
