Help with CPUs
Here is what you need for the best performance per dollar for gaming/streaming/recording/editing/rendering...the FX-8320 is just as good as the FX-8350
only lower clock speed but it's the same chip and it's unlock so a simple change of the multiplier wich takes 12 seconds really will make it just as good and
even better than the 8350 and you save $$...this motheboard is the best 970 board it has an 8+2 digital power phase with high quality heatsinked VRM's
this motherboard will allow for the craziest overclocks on this chip...and this CPU cooler is the best bang for the bucks it will allow to clock the CPU as far
as 4.6ghz 24/7 no problem, this is the exact kit i'm using for gaming and rendering and i couldn't be any happier...it games extremely well too when paired
with an high-end GPU like a GTX 770 or GTX 780 for example. The CPU cooler is 158mm tall though so make sure it fit in your case, and if you plan on
using two GPU'S (sli/cfx) you have to pick the 990FX version of this motherboard because it has only one 16x PCIe slot, the 2nd slot is running at 4x speed.
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($148.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ NCIX US)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($89.99 @ Amazon)
Total: $268.97
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-07 08:46 EDT-0400)
