Strange WiFi issue
1 hour ago, Stahlmann said:
I'm gonna try something else and set my router to work as an access point with it's own SSID and password, as this is pretty much what it's used for atm.
If you do this, it won’t do what you seemingly want it to do. This is no different then just using the landlords Wifi. A different SSID with 0 firewall or subnet segregation means nothing from a network standpoint. If you set it up in AP mode, you would have 0 network separation from the landlords LAN, which maybe you are fine with, but based on you “wanting your own Wifi”, this wouldn’t do that for you. You both would be able to see each others devices as if you were just using the single SSID from your landlord (basically, this is just adding the complexity of a second AP and SSID for 0 benefit).
If you want network segregation, you need to use your own router as a router, and make sure it’s subnet is not 192.168.1.1 (assuming your landlords is 192.168.1.1… yours just needs to be something different). This can be found in the routers setting somewhere, every router is different.
So set yours to be 1 off from his for ease (you can use any private network as defined here https://en.m.wikipedia.org/wiki/Private_network, but easier to just do 192.168.2.1 for example).
