PC started smoking, how to connect 6 fans
Mysterion04
Hello hello, I'm building a new PC wich I do like 3 to 5 a year.
I bought the PC online, it was for a very good price and good components.. And i just make it more pretty and sell it again; Cablemod Cables, Vertical GPU Mounth, RAM cooler RGB etc..
Long Story short.. There are 6 Corsair SP120 RGB Corsair in the Case. They are only 3 Pins, plus another cable for the RGB HUB Controll. Havn't seen only 3 Pin Fans since a very long time. Normally i work with 4 Pin or Fans that comes with a HUB with remote controll where you can change speed and color.
So the thing is. The dude from which I bought the PC from had only 4 of those fans installed (he gave me 2 unused for free). And those 4 were seperated connected to the motherboard. And i don't wont that, cause like i said, You shouldnt see cables all around the place.
So I connected the fans to fan Splitters - 3pin-1200x1200.jpg.e1da6a491c8a631ddd0cdbf533d7c080.jpg
2 of those.. For all 6. But the fans were running at full speed all the time then obviously. and with 6 fans plus CPU Fan, it's to loud.
So I ordered this - SATA_motherboard-sata-4-pin-1-zu-8-3-pin-pwm_variants-1.thumb.jpg.4e0886dcce21ab4b5912612e06840dcc.jpg
And connected my 6 fans to this and get the power from the sata cable. So you can switch the voltage/power for the fans. Off, Low or high. It had only good reviews.
I started the PC and after like 10 seconds the whole thing started to smoke.
And when i turned the switch to off, the rgb turned off too, even though the rgb stuff is on another cable.
I tested it with another one (bought 3) and connected just 1 fan to it.
It didnt smoke again but it was getting really really hot on the switch thing. So I will not use this stuff. At least not for those fans.
Any ideas why this happens to me? Maybe it works (better) for no rgb fans?
And how can i connect those fans that it doesnt run on fullspeed. I don't want it to connect seperat on my mainboard. And i don't even know if it has 6 fan pins.
Motherboard is MSI X470 Gaming Plus
Thanks for all your tipps already and sorry for my bad english 😢
you might have fried something ether this fan controller or something else.
I think the corsair fans needed to be plugged in to a corsair fan and rgb hub
The sps i bought came with a commander pro and it didnt even work properly (flashing rgb)  untill i got the new commander core or whatever and it works fine even with fan splitters plugged into it.
What have you plugged the sps rgb into?
https://www.corsair.com/uk/en/Categories/Products/Accessories-|-Parts/CORSAIR-iCUE-COMMANDER-CORE-XT-Smart-RGB-Lighting-and-Fan-Speed-Controller/p/CL-9011112-WW
Somethng like this allows you to control the corsair fans via corsair i cue and you can controll all fans individually as it also plugs into a usb 2.0 header on the motherboard.
Ive used that exact same hub with zero issues in builds but with generic fans
Could be faulty components in a batch they shipped.  Those fans run at either 7v or 12v perhaps thats just a shitty resistor and its building up far to much heat resisting?  What is LOW rated on the hub?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Maybe 1 or more of those fans is faulty?
Those are 12V 0.3A fans.
The fan controller you've ordered uses only 1 12V from the Sata power and those are rated at a max of 1.5A (per 12V).
1.5A would be 5 fans if they were ideally at 0.3A but there's a chance of the fans needing a bit more or less.
I would not put more than 4 of those fans on a single controller like that. The SATA power cable might burn.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
sounds like a voltage issue. fan cables if they have too high a voltage can rapidly heat smoke then melt. it is a simple thing to get wrong especially with many modern fans cables that want the 5v not a 12 volt. 12 v of some things as fans with a separate rgb 5v will just melt and burn within a matter of seconds if by accident put on a 12v line.
It's not a current issue.
The SATA connector can supply 4.5A of current on 3.3v,  5v and 12v ... the fans consume around 0.1A .. 0.3A on 12v  (maybe double this for a few seconds when they start spinning)  so even with 6 fans connected to it the sata connector would be able to supply the amount of power.
The adapter seems to be using that slide switch to limit the voltage going to the fan by messing around to how the 12v and ground wires of the fans are connected to the sata connector.
I would guess HI speed means  12v goes to 12v in sata connector, ground to ground.
For LOW the switch may replace the ground with 5v,  12v and 5v becomes ground, so the fan "sees" 7v and spins slower... but some power supplies really don't like that, and on some models it can even damage the power supply internally.
On those Corsair fans, the 3 pin connector should be connected to such adapter, while the cable for rgb control should go to the proper fan controller.
Now here's the thing ... if inside the fan, the ground for the motor is joined together with the ground for the rgb leds, it could be that connector for rgb control has the ground wire connected to ground, but when you're switching that to LOW you're connecting the ground wire of the fan to 5v. So, basically, you're creating a short circuit between 5v and ground, and the weakest element in the chain will fail - either the trace on the circuit board going to the sata connector, or the thin ground wire of the fan...
Anyway, just guesses,
I would get a multimeter and with just the adapter connected to a sata connector, I would measure the voltage across the pins in each header, and see what voltage is when in LOW mode. Then measure voltage between a known ground point (ex the metal case of the computer or the middle wires in the old molex hard drive connectors) and the ground pin in the fan headers ... if you see 5v on that pin when the adapter is on LOW mode, then it's like I said above.
21 minutes ago, mariushm said:
-snip-
I love reading your responses.
