Hey guys, i want to know if theres something i can improve on my system, or if something is overkill, thank you!
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
https://linustechtips.com/topic/1487066-thoughts-on-my-build/
I see you put only 1 RAM stick. Single Channel decreases the performance a lot on Ryzen platforms.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792146
Signle channel ram cripples performance on modern cpu's you need 2 sticks. Can have a 15-80% performance impact in games.
At this budget intel 13th gen should really be looked at or even 12th gen as both are faster and absolutly fit in the budget.
Expensive case that has poor airflow savinf there can give you a much better pc.
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792158
https://de.pcpartpicker.com/list/zNBQW4
Idk what your budget is but looks close to 1000 so heres a build for 1000
Gpu used obviously, 3080 and 6900xt cost the same (550€) on ebay so depends on if you want nvidias features + ray tracing or raw performance
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792241
alright ill keep it in mind when i upgrade
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792374
oh i already have the gpu, i just wanted to see what i could improve on it, whats the best pair with my cpu?
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792376
like fps? bc with the pc ive seen extremely long booting times and starting up apps and anything related to opening stuff, also whats the fps gain if i have 2 sticks?
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792383
Depends on the game, in some cases double or more
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792395
Dual channel affects the stuff you mentioned, but even without it, doing that from an SSD with a Ryzen and enough RAM everything should be snappy.
Latest motherboard bios?
Latest Chipset drivers downloaded from AMD?
XMP (DOCP) loaded in the Bios?
The OS installed on the SSD and not on a HDD?
Enough free space on the SSD (at least 20%)?
SSD health good (Hard Disk Sentinel)?
Edit: wait, didn't we already talk about your system, the single channel ram and the slow opening of stuff?
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792396
woah, thats like really old games right? i play rocket league, warzone 2, star wars the old republic, rainbow six siege, whats the performance increase u think in each game?
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792397
latest bios
idk about chipset but i download and installed everything from the mobo support site so most likely
XMP i havent checked, where would that be in bios? but i think i enqbled it on first boot
OS is installed on my NVME (3gb read, 1gb write)
about 22% free on the disk, but hard to do since its 250gb, sometimes it goes to 7% left
didnt check SSD health yet, do i use christaldiskmark?
yes we did talk about it, but after all the fixes u sent it stil didnt work (grey screen and flickering still occuring) , but this time i shared entire build (case is different but not found on site, i am willing to spend more on the pc, so beside an extra stick of ram i wanna see what i can improve, most likely gonna get the lexar nvme as listed above)
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792411
Really old games aren't really ram intensive like todays games, so I'm talking about within the last 7+ years till today
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792414
If you've downloaded from the website of the motherboard, congrats, you have extremeljy old chipset drivers.
Here's the latest: https://www.amd.com/en/support/chipsets/amd-socket-am4/b550
You can check in CPU-Z, if it shows the RAM running 1600 (3200) then XMP is loaded.
Don't let the SSD fil lthat much. Move the downloads folder to the other drive, maybe the documents folder too, use Disk Cleanup to free space, ...
As for the health, you can use CrystalDiskInfo (not CrystalDiskMark), but I recommend Hard Disk Sentinel.
Disabling MPO didn't help?
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792423
so the games i listed above should have abut a 20 fps increase minimum right?
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792427
yes ram is running 1600, and ill get the chipset drivers, btw, what is chipset? god i sound like such a newbie
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792429
disabling MPO didnt help indeed
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792432
oh and some extra info, sometimes when playing a game and watching youtube, the screen (especialy taskbar and youtube) looks like a folded courtain (idk how to explain else, like the ridges when you unfold something, like stripes) show up on the screen that are a tad bit darker, and my entire display starts flickering very fast between dark and a bit lighter
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792441
Cant say definitively, I've personally never played those, however nonmatter what  it will be an obvious improvement, will that improvement be 20 fps? in some yes, in some no, in others way more than 20
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792453
Consider the chipset as a controller that coordinates the communication between the different parts on the motherboard, the parts you add into the system and the peripherals.
Years ago it consisted of a southbridge, northbridge and memory controller. In the recent years the memory controller moved to the CPU and the NB/SB became one.
Interesting.
Check your monitor settings (in the monitors, not in windows), disable any power saving modes, dynamic contrast, Eco modes, interpolation...
Make sure all the displays are using the highest resolution they can and the max refresh rates.
try with different display cables.
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792455
yes i have done this, i unfortunatly do not have another displayport cable, the thing i it did this on my laptop too (connected via displayport with a DP to MiniDP adapter, adapter not faulty) and this issue was so severe it caused BURN IN (monitor is IPS), fortnunatly it coud fade away, whenever closing youtube and the game it would calm down, after a restart it would be completely gonae, the thing is, when toucheing the screen of the monitor while its happening the monitor is extremely hot, the power cable of said monitor is connected to a bar with multiple plugs
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792463
Wait, the monitor did that without the PC even being connected?! Then that is not the PC issue, it's the cable or the monitor itself!
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792466
i did not mention the monitor not being conected to the pc, it wa conected to the pc and previously conected to laptop, the laptop and pc both have ryzen processors, when doing the exact same thing on the pc (gaming with youtube) it does not do this, it only hapened once when starting an old game and very lightly, also, youtube was open on my LAPTOP screen, not monitor i was talking about, yet it caused burn in on the main monitor (only happened while playing minecraft for some reason) so my guess is laptop was faulty (had to rma it multiple times before this issue)
Setup:
https://linustechtips.com/topic/1487066-thoughts-on-my-build/#findComment-15792472
