so context i just moved into a new house and the guy that lived here had a epson eh tw6100w but he hasnt run a hdmi cable from the roof to a accessible place, he has just been using the wireless hdmi box it came with but it turns out it can only do 1080p 60hz wirelessly is there another way to do wireless hdmi were i can plug the receiver into the hdmi on the project and the other receiver into my computer so i can do 1080p 240hz for gaming and 4k 60hz for films
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/1485687-wireless-hdmi-questions/
Reliant on the spec for the projector, if it is only 1.4, it'll only go up to 4k30.
the projector can do 4k 60 hdr wired just dont want to run a wire down the wall
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
I... don't think that's correct.
You're talking about this projector here, correct?
https://www.epson.com.au/products/projector/EH-TW6100W_Specs.asp
It can possibly take a 4K60 input signal, but even if it can, it's downscaling it to 1080p60. The native resolution is literally 1920x1080, so the lens itself will never output more pixels then that.
In fact, the product page, nor the specs page, does not reference the term "4k" at all. Same goes for HDR. HDR10, the basic standard HDR for movies, wasn't even released until 2015.
I also see no mention of 120Hz, let alone 240Hz.
Considering this projector came out in like 2013, I'd be shocked if it had any of these features. The fact that it has built-in Wireless HDMI is actually quite incredible for a projector of this age.
I have a feeling the previous owner lied about what the projector can do, or was seriously mislead himself.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
ye i fucked up i ended up on the 7100w page typo i guess which has the above specs oops
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
A couple of questions:
Do you own or rent? Are you willing to cut holes in the wall, or put stuff on the wall/paint that could damage the paint when removed?
If no to both, then your options are limited, and I would just use the built-in wireless HD option. The specs says it does 1080p/60, which while likely compressed, is the native resolution and framerate of the projector. If you want better quality than what the Wireless option gives you, you need to run some kind of wire (either an HDMI cable, or HDMI over Ethernet which can use a Cat 5e/6/6a cable.
