Pc instability issues?, need help!
1 hour ago, An0maly_76 said:Ryzens and their supporting boards can be quite finicky about RAM. Check your board manufactuer's QVL (compatibility list) for your particular processor (the 3600 is a Matisse) and see if the RAM is listed as being stable. If not, it could be the problem. My 5900X drove me nuts for a few months because it didn't like the memory I originally used. DIMMs tested fine, but I had a few annoying issues that went away when I replaced them with some that were on my board manufacturer's QVL for my processor.
I have pulled my motherboard out to inspect it and I come to find out that the board has damaged caps on one of the VRM leads which I believe to be my problem with the instability and crashing. I guess I learned not to buy refurbished parts!
