ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Help in building pc
 Share
I am planning to build a pc so i did my research and came to  this conclusion
Intel Cpu - i5 13600k=
Asus Gpu - rtx 3060ti=
Asus Motherboard lga 1700 socket with wifi =
Mid tower size case Corsair -
Ram 16gb ddr4 or ddr5
Ssd crucial p5 - 1tb= or any other
Liquid cooler Corsair
Power supply corsair 80plusgold 750w=
Can you guys help me where i can reduce my price with these specs.
What games you plan on playing?
@PDifolco@RONOTHAN##
Any questions?... Quote so I get a notification. In troubleshooting, I'm not always experienced.
I'm quite decent at fixing/recommending upgrades/new PC builds. Or explaining. (or copying from Google)
PC:
Ryzen 3 1200 | 16GB DDR4 3200Mhz | B450 | GTX 1050
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Country ? Budget ? Usage ? Why those parts ?
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 / RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
Country india ,
budget 1000usd dollar,
games i play valorant, cs go, ironsight, gta5, cod warzone,
Answer to why those parts because i could fit them within my budget but it went around 200 dollars above the limit .
So thought anyone can suggest me anything without putting in extra bucks
 Share
