rtx 4080 lowering power limit
13 minutes ago, MartinShaju said:Hi, Despite the high price, I have decided to upgrade to 4080 founders edition (from gtx 970), will be running it on ultrawide 1440p, a bit of an overkill but honestly can't reason a better option for the long run. coming to the topic, this card is efficient but still I want to lower power limit to 80 to 90% and not lower, (just using power limit slider with afterburner and not messing with voltage) So far I have seen it wouldn't harm anything but If you guys know any reason not to do it, that will be appreciated, concerned about power as I'm in Europe with a power crisis and even if there is small reason not to limit i'll just leave it as it is and move on. Thanks for reading.
Der8auer has made a video where he tested the cards efficiency (FPS per watt) at different power levels. He achieved the maximum efficiency with around 75%-80% power limit and even though he reduced his power by 20%, he only lost like 5-8% performance. So if you want to save power, reduce your power target/limit to 80%, that's where these cards are the most efficient (as in FPS per watt)
