Well finally settled on a case and ordered it (snapped it up for £90 inc p&p, 151ish dollar's for those across the water). While cruising the web for airflow idea's i came across and settled with this:
Ignore the H100, i plan to use a Kraken x60
My question is what fan's should i use for the 11 other slot's? As i typed this out i realise how overkill this come's across lol, but i like it. The person who done this diagram has bought 2x 120mm NZXT fans and 2x 140mm NZXT fans and 2x 140mm Bitfenix Spectre Pro LED fans, he is using the 4stock case fans also. Should i mimic this? Or is there better option's open for me? Paying premium for fans is an option (just lake longer to buy) but if there's a cheaper option that outputs similar result im all for it.
Regards
Preston
 Motherboard  ROG Strix B350-F Gaming | CPU Ryzen 5 1600 | GPU Sapphire Radeon RX 480 Nitro+ OC  | RAM Corsair Vengeance DDR4 3000MHz 2x8Gb | OS Drive  Crucial MX300 525Gb M.2 | WiFi Card  ASUS PCE-AC68 | Case Switch 810 Gunmetal Grey SE | Storage WD 1.5tb, SanDisk Ultra 3D 500Gb, Samsung 840 EVO 120Gb | NAS Solution Synology 413j 8TB (6TB with 2TB redundancy using Synology Hybrid RAID) | Keyboard SteelSeries APEX | Mouse Razer Naga MMO Edition Green | Fan Controller Sentry LXE | Screens Sony 43" TV | Sound Logitech 5.1 X530
https://linustechtips.com/topic/147990-switch-810-fan-choosing/
I don't think that that many fans is even necessary. For a while, I just used 2 120mm fans in the front of my case, one 140 in the top, and one 120 attached to my H60 and my temps were fine. If you are not using them, remove the drive cages so you will get better airflow.
https://linustechtips.com/topic/147990-switch-810-fan-choosing/#findComment-1976361
This seems like a pretty good fan setup. The rear 140mm fan is unnecessary, and so are the two angled fans on the cages. Also you can do just 2 fans on the rad instead of 4 if you want more silence, temps will still be very good.
https://linustechtips.com/topic/147990-switch-810-fan-choosing/#findComment-1976365
you know you dont HAVE to populate all of them right?
I know i dont HAVE to =p but as i said i like it
So... could anyone suggest actual fans for me please? Or is the fan's he is using perfectly fine ?
https://linustechtips.com/topic/147990-switch-810-fan-choosing/#findComment-1976402
I have a Switch 810, and let me tell you that it's the worst at sound dampening. I'd strongly recommend against populating all the fan slots. In fact I'd recommend the bare minimum needed for decent temperatures. I only have 5 fans in my case. two 140mm stock fans in the front, an AF140 in the rear and a SP120's on the H100i.
I'd just get the quietest fans you can get your hands on with this case.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/147990-switch-810-fan-choosing/#findComment-1976417
Hmm well i have a Sentry LXE on thw way so i can reduce sound etc while idling/netsurfing etc and i generally phase out sound while i game. Still suggest quietest, regardless of airflow?
https://linustechtips.com/topic/147990-switch-810-fan-choosing/#findComment-1976490
