Country: Turkey
Games, programs or workloads that it will be used for: 1080p gaming, photoshopping, video editing/rendering and programming.
Hello there. I want to replace my 15 year old LGA 775 PC to modern one. I have limited budget.
The system i'm building:
CPU: Intel Core i3-12100F
MB: MSI Pro H610M-G
Memory: Kingston FURY Beast 8GB*2 DDR4 3200MHz
GPU: Sapphire Pulse RX 6700 10GB GDDR6
SSD: Hi-Level GMR3500HS 500GB
PSU: Gigabyte P650B 650W 80+ Bronze
Case: Aerocool Zauron Saturn
Is this system compatible? Would CPU bottleneck GPU?
https://linustechtips.com/topic/1476816-first-time-building-a-pc-need-help/
29 minutes ago, Curesto said:
Country: Turkey
MB: MSI Pro H610M-G
There might be a slight CPU bottelneck but nothing too crazy. The system should work just fine once everything is installed correctly
1 hour ago, Curesto said:
Country: Turkey
MB: MSI Pro H610M-G
there would only be a slight CPU bottleneck but:
From what ive seen the rx 6700 (non xt) isnt any faster than the rx 6600xt or 6650xt. since you are going for 1080p, and quite a lot of the use cases you have given would be able to make use of a better CPU, i'd say look for a 6600xt or 6650xt for cheaper than the 6700 and spend the extra money on a 12400f instead of a 12100f.
A 6600 (non xt) would be quite a bit slower for games but if you find that you would need to drop down to a 6600 to be able to afford a 12400f instead of a 12100f then i would go for that instead.
System: AMD R7 5700g (OC to 4.45GHz fixed clock) / Noctua NH-D15 / Gigabyte B550 Gaming X V2 / Gigabyte Waterforce WB RTX 2080 Ti / Crucial 4x8GB DDR4 (OC to 3800MHz Cl16) / 1TB Samsung 970 Evo Plus / Corsair 4000D airflow / Corsair TX650M / BenQ Mobius EX2510 24.5" 1080p 144Hz
I found RX 6700 on sale at the same price of 6600 XT.
Too much price difference between 12100F and 12400F.
Budget (including currency): 800$ or 15.000 Turkish Liras
Country: Turkey
Games, programs or workloads that it will be used for: 1080p gaming, photoshopping, video editing, rendering and programming.
Other details:
Hi. I'm building a budget computer for the tasks mentioned above.
The build:
CPU: AMD Ryzen 5 5600
Motherboard: ASUS TUF GAMING A520M-Plus
GPU: ASUS DUAL RX 6700 XT 12GB
RAM: ADATA XPG 16GB (2x8GB) 3200MHz DDR4
SSD: WD SN570 500GB
PSU: ASUS TUF GAMING 650B 650W 80+ Bronze
Case: ASUS TUF GAMING GT301
I want it to run most demanding games at 1080 ultra settings.
Is this build decent?
Seems decent
But isnt asus usually overpriced asf? You may be able to find b550 at the same price, better psu, maybe even cheaper gpu. But if asus happens to be really cheap and good value over there compared to the competition then theres nothing to improve really
Lol did you even check the prices on these things? Because you are WAY out of your budget (like 7500TL liras). A series chipsets are waste of money, that case, PSU and RAM choice is not a budget choice, its the dumb bling choice.
Country: Turkey
Other details:
The build:
SSD: WD SN570 500GB
get a b550 board
6750 Xt is litreally 10$ more but better (compared to this asus one it is cheaper)
RAM And PSU and case are you really trying a budget build?
 Why 500 Gb storage only you cant even add more than 2 games with windows get atleast 1Tb (sn750 is a fine drive)
Thanks for the suggestions. I have changed some parts and there it is:
MB: Gigabyte B550M-DS3H
RAM: Corsair Vengeance Pro SL 2x8GB 16GB DDR4 3200MHz
SSD: Kingston NV2 1TB
Case: NZXT H510 Flow White
I already own a PSU (Gigabyte P650B 650W 80+ Bronze).
You are still way out of your own budget.
-= Merged =-
 CHRISTIAN MEMBER
