I have the nzxt kraken z73 with 3 Lian Li sl inf fans on it and my cpu temps are on the hot side. my CPU is at 65°c when I'm un google + some background apps, but nothing big. But when i try a cinebench r23 test it's only 52°c. How is this even possible. When I play minecraft my CPU goes to 73°. I cleaned my pc and checked the thermal paste and it didn't change anything. what could I do to fix this?
https://linustechtips.com/topic/1475470-hot-cpu/
Temps are fine and not hot.
https://linustechtips.com/topic/1475470-hot-cpu/#findComment-15711795
I think it goes down to 52 degrees do to thermal throttling.
https://linustechtips.com/topic/1475470-hot-cpu/#findComment-15711824
3 hours ago, gems_bond said:
is it really normal to have 67° when +- idle?
It's not idling when programs like Chrome are running.
No. 90c is typical load temp and it won't thermally throttle until then.
https://linustechtips.com/topic/1475470-hot-cpu/#findComment-15712049
