FSP Hydro PRO 700W or Corsair CV 650W or Thermaltake Smart BM2 650W?
Slidex
My budget is limited and the two most expensive power supplies that I could afford (which are sold in my country) are:
  • FSP Hydro PRO 700W [link]
  • Corsair CV 650W [link]
I know these are not good power supplies, but if you had to choose between the two, which would you choose?
If I see well, both are "Tier C" on PSU Tier List (but I'm not sure if "FSP Hydro PRO 700W" is this one under "low priority units" or the other one:
Tier C:
  • Above "low priority units": FSP / Fortron / Quanhan | Raider II - HEXA 85+ - Hydro GE / Pro - Hyper M85+
  • Under "low priority units": FSP / Fortron / Quanhan | Hydro GD / GSM Lite PRO / MX / K Pro / (M) Pro Bronze - HV Pro - MS 600W - SFX Pro
"FSP Hydro PRO 700W" that I want to buy doesn't have "Bronze" in name, but on their website it is mentioned that it is "80+ Bronze" (In fact, for all "Hydro PRO 500-800W" models it is mentioned that they are "80+ Bronze", but none of them have the word "Bronze" in their name, so I'm not sure if it's under "low priority units" or not).
FSP Hydro PRO 700W looks better to me:
  • 700W > 650W
  • It has protections: OCP/OVP/OPP/SCP (for Corsair CV 650W these are not mentioned at all)
  • It also has various features listed that are not even mentioned for Corsair CV 650W : "Efficiency ≥ 88% @ typical Load", "Active PFC ≥ 0.9" and so on...
On the other hand, there is no warranty mentioned anywhere for FSP Hydro PRO 700W, while for Corsair CV 650W there is + MTBF hours is also mentioned:
Corsair CV 650W:
  • MTBF hours: 100,000 hours
  • Warranty: 3 Year
Thanks!
*Well there is literally no reviews for the FSP unikt, and we do not know anything. The manufacturer can claim all of those, but I owuld not believe them without a review.
Corsair CV 650w is douple forward, but DC-DC on minor rails, so its atleast somewhat decent, there is also reviews for it.  Out of these I owuld get the Corsair CV
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
I just found another option (which fits my budget and is sold in my country): Thermaltake Smart BM2 650W [link].
Not sure if it's better than FSP Hydro PRO 700W, specs are very similar, both are "Tier C"...
OR: ADATA XPG Pylon 650W [link]
You cant go wrong with Thermaltake Smart BM2, because as the name suggests it's a smart choice.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti and RTX 6800 | Corshair psu
