RTX3080 on older PC and 3x 6pin to 8pin connectors
kmx
Hello
Old school PC guy and completely out of touch on this new stuff, can i get some help please.
Im looking at upgrading from a GTX1070 to a RTX3080 and before I push go, im confused on a couple of things.
Performance of the card
I've got an older PC with a i7 4790k and 24GB ram. Will my CPU be fast enough to get good performance from the RTX 3080?
Powering the card
the version im looking at requires 3x 8pin power connectors.
I have an older cooler master V850 with 4x 6 pin PCI power connectors only. Can I just buy 3x '6 to 8 pin' PCI power adapter cables and be ok?
Thanks in advance
4 hours ago, kmx said:
Hello
Powering the card
Thanks in advance
No, the i7-4790K will heavily bottleneck the performance of a RTX 3080.
The CoolerMaster V850 is 6-pin on the PSU side, but should be 6+2 on the GPU end.
That is the purpose of it... you can combine the 6+2 to make an 8-pin PCI-E power connector.
Use 3x separate cables (i.e. don't daisy-chain).
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
A 4790k isnt even good for a 1070, so a 3080 will be a bit problem.
I only use 2x6 pins for my 3090. Psu should be perfectly fine, especially given how low the card will be performing.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
lmao 4790k is PLENTY for a 1070, more than enough
Buuuuuut not a 3080, unless running games at 4k 60hz
It isnt but I get it some peoples standards are subjective.
thanks very much, really appreciate the help
I suspected my old chip would be a problem.
I found this website that tells me how crap my CPU is with modern cards, I didnt realise it was this bad. Thanks so much everyone, I will stick with the 1070 for now and just buy a whole new computer at some stage.
So glad I asked first. thanks!
i would say, if yer in no hurry
upgrade you cpu & mobo 1st, since 3080 price might drop more
u can always use yer 4790k for unraid nas once u have a new cpu+mobo
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
+1 to upgrade the mobo, the CPU and the memory before changing the 1070. It's still quite a capable GPU, i mean i still use mine with 5800X3D and it still hangs on. That 4790 though - you can form a memorial to it. It's a proper relic now. Get a 7600X with B650 mobo and 2x16GB DDR 5, so if after 2-3 years you want more performance you could simply drop in a new CPU and a BIOS flash. Intel 13th gen CPUs are good CPUs, BUT aren't exactly a great upgrade option because it's basically a deadend platform. Same for AM4.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
No, objectively it’s enough for a 1070- it is able to handle the max frames a 1070 can produce in 99% of games. Hell even a 1070-1080ti. Until you produce some objective data showing that it isn’t enough, I will go off my own testing with a 1060 6gb, a 1070 8gb, a 1070ti 8gb, and a 1080 8gb.
Well, idk about the 4790k, but as i guy who rocked the same EVGA GTX 1070 FTW2 from Ryzen 2700X through 3600X, 3700X, 5600X and now 5800X3D i can tell you there were some pretty big jumps when i switched to each new CPU. The first big jump was 2700X to 3600X, then 3600X to 3700X was lesser one, but still in double digits, then again big jump from 3700X to 5600X and from 5600X to 5800X3D wasn't a jump - it was a rocket launch. Even when you think your GPU is more than enough for the CPU, it still matters. With all CPUs the card was 98%+ utilization, it's the CPU utilization which got lower and lower the further i moved on the ryzen line. With the 2700X it would've been basically impossible to play ACC at 1440p at anything above low to medium details. The only CPU that is from the same ballyard as the 4790k form my list is the 2700X, all of the rest are considerable step forward. At 3000 series ryzen is where Intel finally somewhat got their sh!t together and came out with the 10th gen to be compatible again.
No.
Powering the card
Don't use old, out-of-warranty PSU's on builds you care about.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Well I'll go off my own testing, it isnt enough for a 1080ti either. Cpu is far too weak.
4790K overclocked beats i7-7700, by no means is it a weak CPU. Haswell was the best release, price-performance, until 10th gen.
K.
Like by no means is it good enough for the 3080 or even a 2080 at anything but 4k60 or higher res, but it’s definitely more than enough for a 10 series card
Yea just dont play 1080p and expect high frames without pegging the cpu to 100% for any cpu intensive game. Most people tend to be 30 frame gamers nowadays.
And which are these CPU intensive games? The one game that utilizes my CPU the most is ACC. In all of the others, CPU utilization is 15-20% max at 1080p, in ACC it occasionally gets to about 35%. No other game comes even close to it. That's why the X3D just decimates everything there including OC-ed 13900k.
Any cod and most battlefield games. Only ones I play, so only ones I have to deal with.
