Massive issue with Edge on Android, see attachments
Solved by Gokul_P,
16 hours ago, Neroon said:Looks like you are correct, gboard works fine. Considering this is the only place where I have had this issue, the question is what causes the issue all the sudden, a change to the keyboard or the forum.
Keyboard prob it is prob a bug indroudced in android 13 and seems has gone away with the last patch (it comes out on 31-12-2022 / 1-1-2023 i dont really remeber it but now there is no problem and it is typed from samsung keyboard )
