iMac 27" Late 2013 - Does it hold up for 2022?
I'd recommend buying the highest end model you can find within your budget. Especially if your dad is the type to keep computers forever and run them into the ground. A Core i7 and 16GB of RAM can go a long way.
I have a 2010 27" iMac that I upgraded the CPU(i3-330 to i7-860), RAM(4GB to 8GB), and added an SSD in. It's not great, but it's usable for basic web browsing and some lighter applications.
Apple products do work with apps outside the appstore, it just depends on what you want to use and if it's available for your operating system. Keep in mind that recent versions of macOS(I think Mojave and onward, I could be wrong) do not have support for 32-bit applications. I download apps mostly from the internet, but I have a few on my MacBook that come from the appstore.
I'm not aware of anything that should prevent his iPhone 13 from connecting to a Mac running a somewhat modern Mac OSX/macOS version.
Another option could be a slightly older MacBook Pro, such as a 2015 15". Nearly any Intel MacBook is gonna be a steal, they've been plummeting in price on the used/refurbished market since the M1 released. If you go the MacBook route, I'd recommend looking for a Pro from 2013, 2014, or 2015 if you need all the ports, or 2019 if you don't mind the Touchbar and needing dongles/adapters.
Just now, kriptcs said:Well...lack of money mainly. So you're saying that all mac devices before 2022 will be pretty much screwed?
Not for a while, but it's coming. Right now, I'd largely consider it as something to keep in mind moreso than an immediate problem to watch out for.
What's your budget?
