Anything problematic with this first build?
Go to solution Solved by NF-A12x25,
6 minutes ago, ArunSH said:
Are there any psu you recommend with more 8-pin connectors?
anything A or B tier on the PSU Tier List: https://cultists.network/140/psu-tier-list/
Just pick the cheapest one
Most should have 2 8-pin connectors
Budget (including currency): About 17500kr nok (about 1750$ usd)
Country: Norway
Games, programs or workloads that it will be used for: 1440p gaming for all types of games. Maybe streaming in the future, but its not so important.
Just doing one last check before buying everything for my first build. Here's the list: https://no.pcpartpicker.com/list/LNcJXy
The total price in the list is not accurate. Everything in total is 17700kr or about 1770$. It's a little overbudget, but its fine as long as it doesn't go beyond this price.
Questions:
Will my psu and cooler fit? Is there anything else that doesn't fit this case?
Is fractal psu good? (Someone told me that fractal makes bad psu and that corsair is better, even though it puts me over budget)
Should i go for 750w psu? (This will put me overbudget, but it's fine if it's worth it)
In the notes in pcpartpicker it says something about 4 pin, but i don't know what it means. Is it bad?
Do i need to buy extra cables for something?
Is building a pc setup with this case the same as building other pc setups with mid towers.
Sorry for my bad english.
Edit:
Is 6 cores enough or should i buy cpu with more cores? (This will also put me overbudget, but again it's fine if it's worth it)
Does this motherboard have bluetooth?
Edited by ArunSH
Didn't get to ask all my questions
https://linustechtips.com/topic/1472780-anything-problematic-with-this-first-build/
you’re fine with 650w but not that PSU, as that psu only has 1 8-pin connector. Find a different power supply that has more 8-pin CPU connectors.
they’re wrong. That’s a good PSU it just doesn’t have enough cables for your motherboard.
Also it would be better for you to go with an Intel 13th gen i5 and b660 motherboard with bios flashback as it will be cheaper.
to be more specific for example a 650W Phanteks AMP or 850W SeaSonic B12
right @NF-A12x25 ?
but @ArunSH if you find anything cheaper that you think is up on the tierlist we can check for you..
current PC:
PC configs I used before:
right @NF-A12x25 ?
How about Corsair TX750M, 750W PSU
I think it sounds good:
current PC:
does it have the 2 8 pins?
current PC:
I don't really know since all this is new to me, but here is what the retailer i'm buying from says. It's google translate from norwegian to english so its probably hard to understand:
1 x power 24-pin ATX
2 x power 8-pin EPS12V with removable 4-pin ATX12V part
4 x 8-pin PCI Express power with removable 2-pin part
4 x 4-pin internal power
7 x 15-pin Serial ATA power
Its also semi modular, not full. Is that bad?
Edited by ArunSH
sounds like it's got one
yo @RONOTHAN##@PDifolco does TX750M have at least 2 8pin or whatever this build needs?
current PC:
idk but
1/ you don't really need any second CPU 4 or 8pin unless you need more than 250W (and thus only on recent i9 and threadrippers)
2/ I'm sure the Rmx850 has one cause I got one, so OP can just get that
1 minute ago, PDifolco said:
idk but
so how do you explain first comment?
current PC:
right @NF-A12x25 ?
sounds about right
it has 2 cables, it’s perfect for your build if it’s cheap enough
Semi modular is fine, no difference in quality
