Hello
I just bought SoundMagic E10s and tried them on. Superior to my stock Sony earphones that came with the phone.
But it was the first time I ever used in-ears, and my ears hurt. So I swapped some tips arround, and finally settled for smallest, but it was little help.
Is this reaction normal? I'm concerned, because I like the isolation factor, and they sound so much better, but it feels funny to have them in, also insertion is somewhat difficult.
"Never trust anyone and rely on your instincts" - If you know who said it, you're awesome
https://linustechtips.com/topic/147261-first-time-using-in-ears/
Any in-ears and just plain old earbuds hurt my ears so.  :lol:
https://linustechtips.com/topic/147261-first-time-using-in-ears/#findComment-1967085
It will take getting used to, so it hurts for the first couple of times,but that is for every earbud thesame
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/147261-first-time-using-in-ears/#findComment-1967088
you'll soon get used to it, my ears were uncomfortable at first but later settled.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/147261-first-time-using-in-ears/#findComment-1967093
Comply eartips might help but that is really all you can do. It should get better over time. My first in-ears were really uncomfortable because I was not used to having something in my ear. I got used to it after a while.
https://linustechtips.com/topic/147261-first-time-using-in-ears/#findComment-1967105
