Optiplex 7010 mt power
Solved by jaslion,
14 minutes ago, rour75 said:
Looks fine. Unkown psu is a bit urksome so defo check for that that its a good unit. Wouldnt wanna blow the system.
If you need the screens and all too not a bad deal at all. Pretty good actually.
Case does look closed in the front which aint good for ventilation but that is fixable in multiple ways.
