Building a surprise budget computer for a friend, any help with final touches?
Solved by Mark Kaine,
10 minutes ago, shactheorb15 said:That would probably work great, but Bluetooth is also a priority and I'd like to avoid taking up 2 USB ports if I can
this is for bt + wifi ...
they basically never say bt... but it indeed does bt also.
and yeah it takes up 1 usb, but thats worth it, wifi cards use up a slot on the mobo and possibly disrupt airflow, not much better imo.
