PCIE lanes question help
CPU has some PCI-E lanes then more come from the chipset. The ones directly leading to the CPU are considered faster (lower latency?). On desktops that's usually the top x16 slot and the top M.2 NVMe slot I think...varies per CPU/chipset.
ARK page for 12700H says 28 PCI-E lanes, CPU on PCI-E 4.0, Chipset on 3.0.
M.2. SSD is on 4.0, x4 lanes. In the spec sheet their secondary storage is listed using the same NVMe options, so highly likely your assumption about 16 (GPU) + 4 + 4 (2 NVMe on 4.0) is correct. Probably safe to assume the dGPU is on x16? I can't find a full chipset diagram either though. iGPU isn't counted in CPU PCI-E lanes.
https://support.hp.com/us-en/document/ish_6507941-6507994-16
Note I'm basing this entirely on the specs of the drives listed for both primary and secondary being 4.0 and Intel's ARK page saying the lanes coming from the associated chipset are 3.0. Perhaps the remaining x4 4.0 are going to the chipset as well.
