Is condensation on GPU radiator fans normal?
Solved by jaslion,
14 minutes ago, cleric_warlock said:Yep, just wiped the stuff off and it came up yellow on the towel. Do I need to replace the fans?
Nope. Happens sometimes. Worst case reoil with proper lubricant noctuas allow that.
Deni_I ·
Posted in Storage Devices2 -
Krewtoxin ·
Posted in Laptops and Pre-Built Systems2 -
2
Nexti88 ·
Posted in CPUs, Motherboards, and Memory5 -
HyperPro_Andrew118 ·
Posted in Graphics Cards1 -
tanjackson ·
Posted in New Builds and Planning5 -
7
rich_az ·
Posted in New Builds and Planning3
