Budget (including currency): 600 - 700 American dollars
Country: America
Games, programs or workloads that it will be used for: Gaming, programming work, and video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Already have a case a NZXT H510 and all peripherals
https://linustechtips.com/topic/1466611-first-build-looking-for-parts-optimization/
Parts seem good to me, what do you think? @ShawtyT30beTHICCC
current PC:
PC configs I used before:
Pretty good list honestly, I'll quote the OP my few changes.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
Country: America
Here: Much better gpu, less overkill SSD, much better PSU
PCPartPicker Part List: https://pcpartpicker.com/list/pLbzsL
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($118.99 @ Newegg)
Motherboard: ASRock B550 Phantom Gaming 4 ATX AM4 Motherboard  ($84.99 @ Newegg)
Memory: Neo Forza FAYE 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($43.99 @ Newegg Sellers)
Storage: Solidigm P41 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($39.99 @ Newegg)
Video Card: ASRock Radeon RX6700XT CLD 12G Radeon RX 6700 XT 12 GB Video Card  ($349.99 @ Newegg)
Power Supply: Phanteks AMP 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $707.94
Generated by PCPartPicker 2022-11-09 15:40 EST-0500
B550 Phantom Gaming 4 is OK with that 5600, but Phantom Gaming is Asrock's "cutting corners to make cheapest" series, so you're losing a lot of things just to save a couple dollars. You have very few USB connectors on the IO shield, you don't get usb 10g front panel header which could probably be useful as the nzxt h510 seems to have such connector in front panel... you get old onboard audio (ALC887), only 4 usb 3.0 and 2 usb 2.0, no usb type c in the back , no usb 10g in the back etc etc
It's also a board made with less layers, so it will probably be more picky about what ram sticks you use, and those cheap from less known brands are often made with less popular ram chips (like Hynix or nanya for example) which may not be supported
For example, better options would be
$90 ASRock B550M PG RIPTIDE : https://www.newegg.com/asrock-b550m-pg-riptide/p/N82E16813162065
Only if it must be cheap ... It's basically the Phantom Gaming 4 "refresh" so still weakish VRM (but perfectly fine with a 5600), but now it has  2.5g ethernet, has a couple usb 10g ports in the back besides the 4 usb 3.0 (5gbps) and 2 usb 2.0 and also has that usb 10g front panel header.
$110 MSI Pro B550M-VC WIFI  : https://pcpartpicker.com/product/tr4Ycf/msi-pro-b550m-vc-wifi-micro-atx-am4-motherboard-pro-b550m-vc-wifi
You get what the above gives you but a bit better VRM and a bit better memory compatibility and wireless.
Seems to be a new model, a variation of the classic B550M Pro-VDH WiFI - they updated the wifi to WiFi 6E and wasted pcb space with 3 pci-e x16 unde the video card pci-e x16 slot, those 3 pci-e x16 all have just one pci-e lane so nothing special.
You also chose some things that have mail-in rebates, $60 worth of those ... those can be hit and miss, and you may get a check months after you send the barcodes and all the information, so I wouldn't rely on those. I suspect the power supply has that discount, and I guess it's OK at $35 and 550w is fine for that system but you could probably get a decent psu at 50-60$ without rebates.
You went with that SN850 because it's pci-e 4.0, but you don't really need to spend extra just because it's pci-e 4.0 - you'd be better off going with a decent pci-e 3.0 and higher capacity
Some examples
If you want cheap, $65 Crucial P2  1 TB : https://pcpartpicker.com/product/KMkgXL/crucial-p2-1-tb-m2-2280-nvme-solid-state-drive-ct1000p2ssd8
It's QLC but reasonable drive, for light video editing will be OK.
80$ gets you decent TLC with high endurance and speed , WD SN570 1 TB : https://pcpartpicker.com/product/3dvdnQ/western-digital-blue-sn570-1-tb-m2-2280-nvme-solid-state-drive-wds100t3b0c
Some examples
What do you think about the Gigabyte B550 GAMING X V2 ATX AM4 Motherboard
It's OK but not better than what I suggested above.  Looks to me like you're stuck on ATX but mATX motherboards are perfectly fine for your needs.
On the cheaper end, the only thing ATX motherboards add is just one or two extra pci-e slots, which are often nearly useless (and often they're disabled if you decide to add a second nvme m.2 SSD because the pci-e lanes for those slots are "shared" with that m.2 connector.
On this model and Aorus Elite, I don't like that they have DVI and HDMI on the IO shield - I'd rather have DIsplayPort - DVI is outdated, and it's not capable of more than 1920x1200 at 60 Hz (basically it's dvi single link), so no second 4K monitor for you if you use integrated graphics.
In your case you have separate video card so it's not important.
There's also no usb type-c on the back, and only 6 usb - 2 usb 2.0, 3 usb 3.0 5 gbps and only 1 usb 10gbps - the front panel connector is the 5gbps (usb 3.0 type-c) kind, not 10gbps.
