PC case exposed metal, if left as is will it cause issues?
Solved by manikyath,
i'm not sure if that part of the meshify is aluminium or steel, so i'll cover both:
- if it's aluminium: you're fine.
- if it's steel, it depends. if you're in a very rust-prone climate, like hot coastal cities, it'll probably form some rust. but as long as you dont have your case sitting out in the weather i doubt it'll form problematic amounts before the computer has gone obsolete.
if you want to be certain, cover it with some nail polish or similar.
